Headlight Fuse
Old Nov 23, 2012 | 03:05 PM
Ryan02Stang's Avatar
Ryan02Stang is on a distinguished road
Default Headlight Fuse
I installed an HID kit last week and the lights worked great all week. Last night both lights just went out at the same time. I assume its a fuse since both went out simultaneously and won't go back on.
Does anyone know which fuse to change for the low beam headlights? Any suggestions on a specific fuse to use?
Thanks!
Old Nov 23, 2012 | 05:04 PM
maryjane's Avatar
maryjane is on a distinguished road
check your relay switch located in the glove box
Old Nov 24, 2012 | 03:42 PM
Ok...so I went in the glove box, and took off the panel that said "Relay Access"
There is three box looking things in there plugged in. What do I do?
I don't see a switch...
Thanks for the help!
Old Nov 24, 2012 | 03:52 PM
richphotos's Avatar
Those are the relays, find out which is for the headlights, remove it, and replace it with a new one from the parts store
Old Nov 24, 2012 | 06:05 PM
Ok thanks....I'll buy a new relay and try it out....
Old Nov 25, 2012 | 11:36 AM
Ok...so I pulled out the headlight relay, and plugged it back in, and now one headlights works. Really odd...
I'm going to try getting a new relay and seeing what it does....
Old Nov 25, 2012 | 12:20 PM
I got a new relay and put it in....still only have the passenger side HID fire up. Driver side has day time running lights and high beams working...but the HID won'd fire up.
Is it possible the HID fried when the relay popped?
Old Nov 25, 2012 | 12:28 PM
richphotos's Avatar
Did you try reversing the polarity on the HIDs? unhook them and flip them 180°
Old Nov 25, 2012 | 12:31 PM
Would the polarity reverse itself?
When I installed the HID's I did have to reverse the polarity on each one. The HID's were working fine for a few days, and then both just shut off. I switched the relay in the glovebox and now the passenger HID works but the driver doesn't.
Old Nov 25, 2012 | 02:26 PM
richphotos's Avatar
Well since you already reversed the polarity when you installed them. I would go around and check all your connections, make sure they are clean.
Also, try switching your ballast and bulbs from one side to the other just to rule out a bad ballast. or bulb
