HeadLight Issues
Old Jun 14, 2013 | 04:41 PM
choppercopper21's Avatar
choppercopper21 is on a distinguished road
Default HeadLight Issues
I have a 2000 zr2 blazer that has headlight issues. It seems the daytime running lights don't come on like they should at all. This is my forth blazer so I know something isn't right so I have to manually turn them on when it's cloudy/dark out. Also, when my lowbeams are on, only the drivers side works, not the passenger side and the high beams are also on both sides but they are really dim. When I change it to highbeams, the same issue happens, the drivers side works but the passenger side doesn't and the low beams are on still but really dim. We already checked for a ground issue and it seems there isn't any under both sides. I'm not sure what to think anymore...HELP!!!!
Old Jun 14, 2013 | 06:36 PM
High and low beam lamps use ground side switching through the multifunction switch, relays, and the BCM. Throw in DRL's, AHL's and flash to pass and the circuitry becomes quite complex, plus, ZR2 circuits are different than the regular S&T body. First step is make sure all 4 bulbs are good, not just by looking at them, but by testing them with an ohm meter. If you have a DVOM, (digital volt ohm meter) and are familiar with its use and operation, we can walk you through the diagnosis.
2000P23
Old Jun 15, 2013 | 01:12 AM
richphotos's Avatar
cap... man... you blow me away.. Do you work for GM? LOL
Old Jun 15, 2013 | 09:08 AM
Ok, I'll have to look it over with the bf and see what we will find. Thanks Captain!
Old Jun 15, 2013 | 09:24 AM
Rich, I don't "work" for GM but I do have access to a lot of GM "stuff". Been a master tech & automotive instructor since the early 70's.
Old Jun 15, 2013 | 09:34 AM
chris015's Avatar
ive always wondered about this. You're a Genius. lol. I learn things from you myself.
Old Jun 15, 2013 | 02:37 PM
No, no, not a genius, just experienced
Old Sep 4, 2013 | 10:17 AM
still having issues.........frustrated
Old Sep 4, 2013 | 06:47 PM
What have you checked, and what were the results?
shablaze
Mar 23, 2012 01:43 PM
bman416
Feb 8, 2010 08:29 PM
mandyw
Jan 9, 2009 05:08 PM
chris4172
Aug 23, 2008 04:20 PM
KawBoi
Aug 20, 2008 12:02 PM
