Headlight issues
Old Feb 2, 2019 | 12:01 PM
Westy's Avatar
Westy is on a distinguished road
Default Headlight issues
i wonder if anyone can help please?
my dipped headlight does not work all the time. Main beam is fine, when I dip them the headlights go off, then they flicker and come on.
Turn the lights off completely and then back on and no dipped headlights again.
I have replaced the headlight switch/stalk but still the same.
Where is the relay please?
thanks for any advice
Old Feb 2, 2019 | 12:19 PM
cleburne red's Avatar
Have you checked the connector at the bulb? On different cars, I've had the same issue, the connector was starting to melt, and was making intermittent contact
Old Feb 2, 2019 | 12:32 PM
Westy's Avatar
Both headlamps are doing it though mate. I will check, but both are flickering at the same time.
Old Feb 2, 2019 | 12:55 PM
Hmm, good point. I didn't think about that.
Old Feb 7, 2019 | 05:03 AM
bugsydog's Avatar
bugsydog is on a distinguished road
Default relay
Have you checked under the hood on mine which is rhd there is s hella relay near the ac unit on the firewall .
Rock auto do them from £2.00 to £14. each . Its listed as a blower relay but controls high and low beam . Mine went bad my lights went out completely cleaned the points inside and it worked for a while but needs a new one . Ive ordered a
GPD
1711245 .
Old Feb 10, 2019 | 02:01 PM
Westy's Avatar
Thanks mate I will check
Old Feb 10, 2019 | 02:10 PM
bugsydog's Avatar
Default relay
Your welcome let.me.know how you get on.
Its also listed aa a Hella relay but i out it in the car while im waiting fir the part .I am 99 percent sure this is whats wrong with yours if you tap the case with a screwdriver it may go off and on , inside the relay it has two contacts and they burn out due to the high voltage .
Old Feb 22, 2019 | 10:59 AM
Westy's Avatar
You were correct Bugsydog!
relay!
new one on order
thanks
Old Feb 22, 2019 | 01:43 PM
bugsydog's Avatar
relay!
new one on order
thanks
Great glad it helped nice to be useful
Rayraytonto
Mar 11, 2018 08:53 PM
bertaguy
Sep 19, 2010 09:21 AM
shrubnub
Aug 11, 2010 05:31 PM
WickedBerry
Jun 21, 2009 06:52 PM
2001blazer
Jan 30, 2006 10:45 AM
