Headlights dim when brake pedal is pressed
Old Nov 9, 2010 | 12:58 AM
Dieseldog95's Avatar
Dieseldog95 is on a distinguished road
Unhappy Headlights dim when brake pedal is pressed
I have a 95 Chevy 4 door 4.3L with 186000. Having problems with the lights. When you turn your turn signals on left or right, the amp gage moves from 14 to 12 and is in rythem with the turn signals. Now tonight it started diming the head lights and amp gage going to 9 when the brake pedel is pressed. Have replaced the alternator and battery in the last year and also fixed the ground wire on the back coming off the filler neck. Have cleaned the fuel pump and cleaned the one from the battery to the frame. Still ant had no luck about pull hair out.
Old Nov 9, 2010 | 06:01 AM
2001redblazer's Avatar
2001redblazer is on a distinguished road
i would have the alternator and battey checked,even though they are both fairly new,doesn't mean they can't go bad on ya
Old Nov 10, 2010 | 07:10 PM
Had the alternator checked today and it came back with a clean report. Put back in and load tested the battery and it show 12.8amps and 650 cca.
_HeC_
Feb 10, 2013 04:43 PM
Donnie3543
Aug 13, 2009 12:38 PM
GloryImSaved
Jul 16, 2009 12:50 AM
phil01ss
May 29, 2006 09:21 AM
jaleg
Nov 17, 2004 02:53 PM
