heater acting wierd
Old Feb 20, 2012 | 07:36 PM
gixxerjay40's Avatar
gixxerjay40 is on a distinguished road
Default heater acting wierd
The heat in my blazer when warm blows hot like it is supposed to but it turns to cool air until there is a wierd sound in the dash like a suction sound as if a vaccume line is closing then it goes back to heat then back to cold. ??????
Old Feb 20, 2012 | 07:45 PM
pettyfog's Avatar
Sure it aint more a 'gurgle'?
How does your engine temp gauge act? Does it stay steady at just under 200?
Low coolant/air in your engine cooling system. Open radiator in morning when cool. Should be all the way to the cap.
Check your engine oil dipstick and oil filler cap make sure no milky/chocolaty looking deposits on them
Old Feb 20, 2012 | 08:49 PM
No coolants good checked it several times it like the climate control is always clicking on but there is a definate noise in the dash in drivers side before it swithes to heat like a thermostat is triggeeing the air .
Temps are good too.
Old Feb 20, 2012 | 08:55 PM
xgiovannix12's Avatar
sounds like a vac hose got loose in the dash
like the bend door hose
what are you driving ?
Old Feb 20, 2012 | 08:58 PM
99 blazer Lt
Old Feb 20, 2012 | 09:00 PM
id listen for the hissing sound again and see where its leaking from
Big Ted
Sep 26, 2011 04:33 PM
AEChevy
Jan 14, 2009 10:29 AM
5brown1
Feb 20, 2006 09:26 PM
bfluke3
Feb 1, 2006 11:23 PM
BLAZER98
Nov 28, 2005 11:48 AM
