Help letting me know this???
Old Apr 12, 2012 | 02:54 PM
6victor1's Avatar
6victor1 is on a distinguished road
Default Help letting me know this???
I had a friend fix my ball joints... when I got the truck back, these wires were cut on the driver side tire.... I also noticed that the ABS light stayed on... I disconnected the positive battery terminal while I fixed these wires... when I reattached the battery terminal and started the vehicle, the ABS light was still on.. can anyone tell me what this piece does??
Thank you for the help..
Attached Thumbnails Help letting me know this???-wiring-pics1.jpg   Help letting me know this???-wiring-pics2.jpg
Old Apr 12, 2012 | 03:27 PM
That is the speed sensor for that wheel. The sensor output must be >250mV-AC when you spin the wheel. The sensor may be damaged beyond the wiring. Also, ditch those crimp connectors if you ever hope to have the connections last. Solder the connections & seal with heat shrink tubing (I prefer the 3M tubing with adhesive on the inside).
Old Apr 13, 2012 | 08:02 AM
6victor1's Avatar
Default I thought so....
After I seen the light was still on, I thought that this was the speed sensor... TY for verifying.. I'm going to change the rotors and pads in a few... I will fix this better then... Thanks again...
Can U let me know where the ABS sensors are?... Thanks
Old Apr 13, 2012 | 09:54 AM
pettyfog's Avatar
In the hub, at the end of those wires.
Old Apr 13, 2012 | 12:36 PM
The speed sensor that you repaired the wiring for is an ABS sensor.
bassson
Dec 3, 2013 11:51 PM
Angie Jane Hand Jones
Mar 20, 2013 06:44 PM
Deatherage
Dec 6, 2010 11:45 AM
livlifes2short
Mar 13, 2009 11:26 PM
spankyy
Feb 20, 2009 12:27 AM
