HELP!!! partial electrical loss
Old Mar 15, 2010 | 05:02 PM
Qumodo's Avatar
Qumodo is on a distinguished road
Default HELP!!! partial electrical loss
i am having a weird problem. i have lost partial electrical power. everything works except the radio and my CB (which is powered via accessory port in the fuse box and grounded to the body.) i checked the fuse to the radio and it wasn't blown so I'm at a loss. i was doing a little mudding this morning, nothing very deep and all was fine. i got home and removed the main air intake hose. restarted the engine and now no radio or CB everything else still works fine. any ideas of WTF happened.
p.s. i also added a spring to the base of my CB antenna.
this is a 1989 s10 4.3L 4x4
Old Mar 15, 2010 | 05:19 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
using a grounded test light, test both sides of the fuses at the fusebox, if you have voltage then test at the radio harness ( yellow wire) and the back of the cb (power wire). if you have voltage there then test gound by using a powered test light and check grounds.
Old Mar 16, 2010 | 05:32 PM
Qumodo's Avatar
checked the fuse box today it looks like part of my fuse box has died. i got the CB working again but the radio is still not functioning. that fuse port checked out fine. so now i guess im hunting wires. anyone have any tips for pulling the dash apart??
JoSHN
Sep 14, 2012 04:56 PM
bryanmine
May 19, 2011 11:27 AM
sprkz
Oct 8, 2010 09:35 PM
Bajimer
Nov 16, 2009 10:30 AM
psycoreefer
Oct 8, 2007 11:25 PM
