HID's, confused.
Old Jul 19, 2012 | 11:05 AM
99Legendary's Avatar
99Legendary is on a distinguished road
Default HID's, confused.
I want to get HID's for the blazer.
Question 1: Should I get low beam or high HID's? I want to be able to light up the night. I can't get both.
Question 2: I am looking on HID extra, and I don't see any HID's for a blazer, but I do for a trailblazer. Would I use this? If so, would you mind linking me to the HID's I could get for my 99 blazer ls 4x4?
Question 3: Must I get projectors? If so where, I need ones that are cheap, I can't afford HIDs AND Halo projectors etc.
Question 4: What exactly would I need to get so I can install the HID's successfully?
Thanks guys.
Old Jul 19, 2012 | 11:16 AM
Thogert's Avatar
Hids take a little while to warm up, so using them in the high beams will leave you in the dark for about 10 seconds (depending on the manufacturer) unless you do the high 4 mod.
You will need a
9005 (high beams) or 9006 (low beams) depending on if you want the highs or lows.
Ideally projectors are the safest way to have hids. If you put them in a regular headlight housing you will blind other drivers, not to mention the beam pattern may actually waste the extra light your hids put out.
If you want to do the hids in the low beams, get projectors. If you want the highs, you can use whatever you want because you will only use them when nobody else will be around when you fire them up.
Thanks guys.
Hope that helps.
Edit: Haha you snuck that edit in there on me.
You should get a relay harness so you don't overwhelm your stock headlight wiring and start a fire.
Old Jul 19, 2012 | 11:20 AM
Originally Posted by Thogert
Hope that helps.
Ok Thogert, I will be sticking with the low.
But the "Trailblazer" HIDs that are offered on hidextra.com, are those the ones I should buy?
Also, what kind of projectors should I get. Are there any relatively cheap ones?
Thanks again buddy
Edit: http://www.hidextra.com/Chevy-HID-Kits
Those are all the chevy made HID's
Old Jul 19, 2012 | 11:26 AM
Thogert's Avatar
I'm not too familiar on the projector options out there but I know there are quite a few availible on Ebay.
Here is a link to hidextra for your low beam bulbs.
Old Jul 19, 2012 | 11:29 AM
Thanks Thogert, you are the man, one more question.
It asks if I want a cancellor. Should I get that too? I am not even sure what it does haha.
Old Jul 19, 2012 | 11:31 AM
Thogert's Avatar
No the canceller is for vehicles with bulb out indicators. Our blazers don't have that option, so we don't need them.
Old Jul 19, 2012 | 11:32 AM
Ok, that saves me 10 bucks then, nice!
Thanks for all the help!
jdespain
Lifting Tech
14
Jan 29, 2010 10:07 AM
chiefbong360
Jan 4, 2010 10:27 AM
wstdintllgnce
Nov 28, 2006 11:24 AM
chevychic4life
Engine & Internal
16
Mar 28, 2006 04:29 PM
strongboy2005
Engine & Internal
Feb 9, 2006 06:12 PM
