High Beam Doesn't work
Old Dec 16, 2012 | 01:59 PM
The ground circuits are switched in the multifunction switch. Ground is ultimately supplied by the BCM, (Body Control Module). Driver and passenger side high beams use the same ground path. If the passenger side works, the purple wire has an open circuit somewhere between the splice inside the underhood fuse panel and the driver high beam socket.
Old Dec 17, 2012 | 08:53 AM
mrspeedy69's Avatar
mrspeedy69 is an unknown quantity at this point
Originally Posted by Captain Hook
The headlamps have separate fuses for left & right. Each fuse protects the respective high and low beam filaments. If both low beams work, both fuses are OK. The purple, (high beam ground) wires exit the underhood fuse panel and run seperately to each high beam socket. The one that runs to the left high beam has an open circuit somewhere. You can do one of two things: Locate and repair the open circuit, or, run a jumper wire between the purple wires at each high beam socket. The open circuit could very well be inside the underhood fuse panel. Sounds crazy but, yes, the ground wires connect inside the fuse panel. Post your results
Captain thanks for the advice. I'll take a look at it tonight and see what I can figure out.
Old Dec 21, 2012 | 10:24 AM
mrspeedy69's Avatar
Captain I just want to tell you thanks for your help. You are a wealth of knowledge and we appreciate it.
So the jumper wire worked and both high beams work now. My question now is, is it ok to leave that jumper connected or should I find out where the ground problem actually is and fix it that way?
Old Dec 21, 2012 | 06:05 PM
Thanks for the kind words Glad to help.
The problem is an open circuit in the purple wire: The light doesn't care where you fixed it. If you're OK with running a jumper wire, you're done If not, trace it down.
Old Dec 22, 2012 | 12:48 PM
mrspeedy69's Avatar
Ok that's what I figured. Thanks again I appreciate it.
Old Dec 22, 2012 | 02:02 PM
Glad you got her working, thanks for posting back with the "fix".
Old Apr 30, 2013 | 04:56 PM
paulyabe's Avatar
paulyabe is on a distinguished road
I just went through a similar problem; changed the hi beam/running light bulb, only to find the bulb still won't work on hi beam. It works as a running light though (driver's side). Came here trying to find a solution.
Old Apr 30, 2013 | 09:46 PM
Headlamps use relays on the ground side and can be time consuming to find the problem. It would be best to start a new thread describing the symptoms and we can help you find and fix it.
Mike4x4ing
Jul 6, 2013 01:21 PM
Amelia23
Sep 29, 2012 05:31 PM
ChevyFamily
Jan 27, 2011 01:13 PM
marine
Jan 28, 2010 07:05 PM
dimmuborgir6nik6
Feb 27, 2008 01:34 PM
