Horn is constantly ON
Old Feb 24, 2016 | 12:17 PM
danaandmeegz's Avatar
danaandmeegz is on a distinguished road
Default Horn is constantly ON
As I was pulling out of the parking spot this morning my very loud horn decided it was time to wake up the neighborhood. I jiggled the steering wheel, hit the horn button and nothing stopped it. I had to disconnect the battery to stop it.
I can disconnect the horns so I can get to work, but I realize the relay will remain activated draining my battery. I have a 1986 Astro Van with no alarm system causing this. I suspect either the horn switch or the relay is causing my issue. I want to test the relay before tearing into the column, but I don't know where the relay is located. Under the dash, on the fuse panel, in the engine compartment, etc?
4.3l TB
Thanks, Dan
Old Feb 27, 2016 | 11:22 PM
Thanks for all the help (ha ha)
After pulling the fuse and lining with the ramifications of not having internal lighting and radio memory, I had a chance to put a meter to the circuit and discovered the horn button switch was the problem. a trip to the P/P will remedy that
JTalley
Dec 18, 2010 06:33 PM
xderkax
Jan 14, 2010 11:38 PM
onecrazyfoo4u
Feb 15, 2009 07:42 PM
larsulrik
Sep 20, 2008 02:22 AM
virgs91s10
Nov 14, 2007 01:01 PM
