How to remove tail lights on 2dr 2000 chevy blazer?
Old Jan 29, 2011 | 05:34 PM
retnepracrolyat's Avatar
retnepracrolyat is on a distinguished road
Default How to remove tail lights on 2dr 2000 chevy blazer?
I can get the top screw of the tail light on but one of the bars for the gate is blocking any chance of getting to the 2nd screw, do you have to completely remove the gate to get the tail light off?
Old Jan 29, 2011 | 06:23 PM
old skool luvr's Avatar
while i haven't changed the TL's on a 2 door, i have removed them from a 4 door that had a TG like yours.
i really don't remember it being that difficult to remove the screws. have you tried lifting the bar as you lift the gate? might just be the clearence you need to get @ it.
post a pic of the problem if you need.
Old Jan 29, 2011 | 06:24 PM
blazinloud's Avatar
No, you can unbolt one side of the tailgate support and swing it out of the way. i use needle nose pliers to hold one side of the nut then wrench the other. if you dont hold it, it will just spin.
Old Jan 29, 2011 | 06:29 PM
cbr995's Avatar
Are you referring to the struts? You can just pop the metal tab off the top side of the strut, and drop it out of the way.
Old Jan 29, 2011 | 07:34 PM
i coulda swore he was talkin' about a p/u when i read it!
thanks for pointing that out Matt.
Old Jan 29, 2011 | 09:34 PM
that's not my car but the diagonal bars holding up the gate is what i'm referring to....on the blazer they aren't so flimsy looking and one is completely blocking the bottom bolt
Old Jan 29, 2011 | 10:07 PM
cbr995's Avatar
Yeah that's the struts. Just pop the top of the strut off. It'll give you plenty o' room.
Old Jan 30, 2011 | 08:04 AM
i hope not-'cause it's a truck in the pic!
seriously though, if you're gonna look for a pic to show us what you're refering to, you should @ least grab a pic of the right truck.
that's a 1st gen, in case you didn't know.
Old Jan 31, 2011 | 10:15 AM
ok, i took pics of my actual car. I wasn't able to pull the bars off?
Old Jan 31, 2011 | 01:29 PM
in your last pic, you'll notice that there is a small metal clip-exactly the same as the ones on your rear window pistons. use a small standard screw driver (that's the flat one), and gentle pry it out. then pull the piston off the pivot ball.
easy-peasy.
ludude1975
May 1, 2011 10:09 PM
sidviscious
Oct 8, 2009 08:38 PM
bigmanhargett
Apr 1, 2009 12:05 PM
JTH
Mar 23, 2008 10:29 PM
jah19862003
Dec 31, 2006 11:18 PM
