Ignition short and more
Old May 7, 2024 | 01:26 PM
SpeedySam's Avatar
SpeedySam is on a distinguished road
Default Ignition short and more
Hey everyone. I'm looking for help for my new to me jimmy. Thing had a short between the steering colum and wheel and started smoking. The wire i found shorted led the the key ignition and cut engine power and crank briefly befofe turning back on. I had a CEL before, and turned off after, and opposite with the ABS light as it turned on(may be unrelated, previous owner did mention they occasionally pop on or off) Drove the 2 blocks home, and temporarily fixed that up. After that, my radio, windows, air controls, fuel economy thing, and wipers don't work. No power at all. Only thing I could think is the 20amp and 30amp circuit breakers. Got some from pick n pull and no help, but no gaurentee any of the 2 i found were good. Any other ideas for something i need to look into?
This is a 97 jimmy sls. 4 door, auto, button activated 4x4. 201,000km
thank you all
Old May 8, 2024 | 10:47 AM
GeorgeLG's Avatar
We need to start simple.
  1. Does the starter crank?
  2. If it cranks does it run?
George
Old May 8, 2024 | 03:01 PM
SpeedySam's Avatar
George
Yes everything else functions normally. Runs and drives, just cannot drive as its raining and wipers dont work.
I replaced the 2 circuit breakers (30amp and 20amp) as I thought that may be an issue but no luck. I got 3 of each from pick n pull so assuming at least 1 of them wasn't blown that shouldn't be my issue.
Old May 8, 2024 | 03:13 PM
GeorgeLG's Avatar
Check wiper fuse 17 (25A) in the IP fuse block.
Put the wipers on high, black meter probe on battery ground and probe the 4 wires at the wiper motor module in turn and tell me what you get (4 numbers).
George
Toby Hanson
Oct 21, 2013 01:05 PM
GuySmiley777
Apr 1, 2012 11:19 AM
mansopoor
16
Dec 20, 2010 02:37 PM
eastsiderides
Aug 14, 2009 11:58 PM
bootlegger
Sep 18, 2008 07:50 PM
