Illumination issues
Old May 26, 2018 | 07:02 PM
Blazer117's Avatar
Blazer117 is on a distinguished road
Default Illumination issues
Confused, need input. 1999 blazer Ls, low beams and high beams began working intermittently as the high beams would only engage when i could get the low beams on. Now, the low beams only work with the auto light sensor, no high beams and no control from the multifunction switch which i just replaced two weeks ago. Drl's work, everything else works as normal, other than when i go to turn the lo beams on with the master switch, and theyre already on from the auto lights, it kills them. Checked fuses, checked relays, checked power at the pigtail to the multi function switch. Im tearing into now, any insightful ideas would be a godsend.
bama1fan
Nov 29, 2012 07:25 AM
Nemo1991
Feb 22, 2011 07:02 PM
streblo
Nov 4, 2010 02:00 PM
EuroGoldLS
May 18, 2009 01:18 PM
George
Apr 18, 2008 11:15 AM
