instrument panel has a mind of its own
Old Feb 26, 2013 | 05:23 AM
Nunes Martinez's Avatar
Nunes Martinez is on a distinguished road
Default instrument panel has a mind of its own
Ok so I just got a 91 Chevy S10 blazer, my problem is when I switch on my lights my instrument cluster zeros out. I have no cluster lights either, switch on the high beams and the lights go out completely. My stereo has insufficient power while the vehicle is running, I have a constant brake warning light on, when the lights are on cluster isn't lit etc my turn signal arrows are at a constant but continue to work and blink when engaged. When my door is open everything works fine except for the stereo and high beams.
New development: I just bought and replaced all dome/courtesy lights, they're all at a constant. No manual or dimmer switch affects them. The door jam only dims them.
PLEASE HELP!!!
Old Feb 27, 2013 | 12:38 PM
abig84's Avatar
one thing you can check is i had a similar issue is there is a ground wire on the very bottom left side of the dash that comes loose and causes all sorts of issues. so just basically lay on the floor and look up and it should be a screw facing up
Old Feb 28, 2013 | 05:20 AM
thanks abig84, ill be sure to check that out as soon as its light out
Old Feb 28, 2013 | 08:28 AM
I couldn't find the ground :/ you think you could post a picture of the location?
richphotos
Dec 11, 2012 09:57 AM
Shaun Bogen
Dec 3, 2012 06:47 AM
Kandiss
Feb 24, 2012 07:55 PM
jeepetr
Jul 9, 2011 11:58 AM
Dfretty
Oct 21, 2010 11:31 AM
