Instrument Panel problem???
Old Jul 31, 2013 | 09:05 PM
BlazN's Avatar
BlazN is on a distinguished road
Default Instrument Panel problem???
I've ran out of ideas of what the issue could be, have check every fuse,every wire from the fuse box etc. Anyway the instrument cluster on my 98 Blazer was junk the digital odom/trip meter wouldn't light up for anything also gas needle won't move, today I went and picked one up from a salvage yard for $50 and now the odom/trip meter will work but only one click over with the key. If you turn it anymore or crank it it goes out? Idk what can be causing this. Oh the gas gauge still isn't working. Maybe bad ignition switch??? ECM?? I'm clueless...trip/odom function like they should
Old Aug 1, 2013 | 11:13 AM
BlazN's Avatar
Anyone?
Old Aug 1, 2013 | 11:19 AM
chris015's Avatar
that sir would be your ignition switch going out. 97-98 seems to have this issue.
Old Aug 1, 2013 | 01:19 PM
BlazN's Avatar
That's what I was figuring. Their a bitch also to replace right? What's all involved never had to replace one
Old Aug 4, 2013 | 01:57 AM
burned's Avatar
burned is on a distinguished road
https://blazerforum.com/forum/tech-a...acement-29167/
Old Aug 17, 2013 | 02:53 PM
BlazN's Avatar
Well put a new ignition switch in and didn't change anything still having this problem...any other ideas
blazin4eva
Dec 17, 2009 08:22 AM
trettifire
Oct 3, 2009 08:48 PM
97_blazer
Oct 14, 2007 06:44 PM
recruiter
Jan 5, 2007 02:58 PM
jack
Aug 8, 2006 02:38 AM
