Interior Light stay on
Old May 23, 2011 | 08:26 AM
professor7980's Avatar
professor7980 is on a distinguished road
Default Interior Light stay on
I have a problem with my 97 s10 interior lights staying on after pulling off 2 door panels and replacing one speaker. I have the fuse pulled right now but thats a huge nuisance as now i have none of the other functions of that fuse. any ideas what might be causing this or where to start and the switches on the doors that activate that are still working. so if any one else knows what is wrong would be a huge help
Old May 23, 2011 | 06:14 PM
Rottidog's Avatar
You say the switches are working but are they connected? The switch being pushed IN disconects the power to the interior lights, opposite is true if the switch is out. Perhaps wires are touching inside the panel near the switch. That's where I'd start anyway, by checking as you pull off the panel if any wires are crimped or moved.
Old May 24, 2011 | 09:35 AM
It almost has to be a switch that is not being properly compressed so as to break the ground circuit for the interior lights.
Old May 25, 2011 | 10:42 AM
LowLife's Avatar
LowLife is on a distinguished road
im having a similar problem with my 97 blazer, instead of pulling the fuse just pull the dome light bulb itself, thats what i do for now. until i figure out the root of whats wrong, i swapped out the door jamb switches both sides and everything was fine, after about a week it started acting like my p/side door wasnt shut again keepin the dome light on, i changed the p/side switch with brand new switches 3 times and that aint it if i figure it out before u do i will let u know what my problem was
Old May 25, 2011 | 12:45 PM
Rottidog's Avatar
Just a thought, but sometimes the simplest things get overlooked - is the dimmer switch on the dash turned all the way up?! Wouldn't that be awsome if that was the issue? lol
Old Jun 21, 2011 | 01:23 PM
Thogert's Avatar
So I have the same issue and I would really like to have working cab lights. I checked all of the door jam switches and even the rear glass switch and the light stayed on. Help me please.
Old Jun 21, 2011 | 01:57 PM
How did you check them? Have you checked the wiring for a short to ground on the switch circuit?
I know I have written a very detailed post about how to properly troubleshoot the courtesy light circuit, but I don't really have the time to look for it at the moment.
Old Jun 21, 2011 | 02:01 PM
Thogert's Avatar
Ok, I'll look a little harder, thanks.
augie
Apr 2, 2024 03:28 PM
timmy08753
Jun 18, 2011 08:57 AM
truesmack
Apr 7, 2009 06:48 PM
lt170chevelle
Nov 1, 2008 08:32 PM
hstt
Mar 4, 2006 12:03 AM
