LED Upgrade/No Hazards
Old Dec 19, 2018 | 10:28 PM
dlamb0726's Avatar
dlamb0726 is on a distinguished road
Default LED Upgrade/No Hazards
So I upgraded my brake/tail lights and all four turn signals to LED bulbs. My front marker lights are still Incandescent bulbs. I purchased a turn signal flasher that was both LED and incandescent compatible but now my turn signals only work if the hazard switch is in the ON position and I have no Hazards at all now. Is this a fuse? And where is the hazard flasher I didn't see it beside the turn signal flasher. I have a 2002 blazer LS 4wd 2 door
Old Dec 20, 2018 | 07:07 AM
mr.vls's Avatar
I added LED Flasher and changed the rear bulbs to LED's no problem. But, when I added the front LED's I had the same issue as you. I added LED resistors to the front L/R turn signals and all lights work correctly. I spliced in the resistors behind the front bumper and secured with body molding double sided tape. You need the LED flasher and LED resistors.
Old Dec 20, 2018 | 07:32 AM
dlamb0726's Avatar
Thank you! I will try this
Old Dec 21, 2018 | 06:40 AM
When I did LED's all around I had to put resistors on the front as well to restore function.
Do NOT put resistors in the rear. The turn signal circuit in the rear is also the brake light circuit, so if you're on the brakes for more than 5-10 seconds those resistors get EXTREMELY hot, they're only meant for momentary pulsing like turn signal flashing.
I didn't use an actual LED rated flasher though, I modified the stock flasher by cutting and lifting a leg on an IC on the inside.
https://blazerforum.com/forum/lighti...-insane-71527/
Old Jul 5, 2021 | 02:49 PM
05blazerr's Avatar
05blazerr is on a distinguished road
Hey,
sorry I've struggled to find more info on the resistor placement, may i ask if you have a photo or some more insights?
I also did all led, but the front turns don't blink when I put led in them. I do have a new flasher relay for LED. If I put resistors in will that fix this issue?
Thanks !!
mr.vls
Jul 7, 2018 01:09 PM
Rolandtd
Feb 17, 2016 07:57 PM
Ryanmatt135
15
Mar 7, 2013 06:56 PM
uhlhazard
Jan 5, 2011 01:08 PM
mosca1
Mar 3, 2010 11:05 PM
