Left rear brake light issue
Old Jul 24, 2013 | 04:13 PM
nitromt's Avatar
nitromt is on a distinguished road
Default Left rear brake light issue
I have a 99 jimmy recently i noticed the left rear brake light works when it wants to any idea what might cause this? bulb has been replaced with new one.
Old Jul 24, 2013 | 04:20 PM
richphotos's Avatar
*Moved to Lighting and electrical*
That being said, There could be a short, it could be a bad bulb socket, I would start with the bulb socket, since it is the easiest thing to replace, then if it still acts the same way, start tracing the wires to try and find a short.
Old Jul 25, 2013 | 10:07 AM
nitromt's Avatar
Ill try the socket but i forgot to mention everything else works on that same bulb the hazards the turn signal.
Old Jul 25, 2013 | 04:23 PM
richphotos's Avatar
so the running and brake function work? but the blinker and hazard does not?
Old Aug 6, 2013 | 07:08 PM
nitromt's Avatar
No all the lights work just the left brake light only works off and on but i have found the problem its the wiper/signal switch one day i was in a parking lot and i was looking in the side mirror with the reflection of the car parked behind me i was checking if the brake was working and it wasn't so i moved the signal switch just slightly up and the brake light came on then i moved it down a bit and it went off again. Now my question is am i better off to replace with a new or used one? or is it just a loose connection and i can tighten it up?
Chris99
Jul 19, 2011 08:19 PM
buddanicholson101
Aug 6, 2010 08:49 PM
kiwi
Nov 6, 2009 10:45 PM
calgsblaza
Jun 3, 2008 09:46 PM
Jimonawing
Nov 16, 2007 02:38 AM
