License plate light options?
Old Dec 10, 2014 | 01:53 AM
Radio's Avatar
Radio is on a distinguished road
Default License plate light options?
Here's the issue. I have a 96 Blazer with messed up electricals as is due to poor jury rigging from previous owners. The license plate lights aren't working since one assembly is missing and the other one has a bad bulb I think. I'm trying to find some sort of led light or something similar that can stick to a surface and illuminate the plate thus preventing the local smokies from pulling me over at night.
Old Dec 10, 2014 | 02:09 PM
GoldOlds94's Avatar
GoldOlds94 is on a distinguished road
I would locate ground wire that is mounted somewhere back there to the frame with a screw. I would take fastener out and sand or wire bush the area and see if that works.
Old Dec 10, 2014 | 02:51 PM
Radio's Avatar
Would it be possible to take an after market light and wrap the wire from that around the fastener to make it work? If I wind up going OEM with the license plate light I will be forced to remove the entire bumper. Previous owner put a steel ford bumper on as a replacement. Ugh...
Old Dec 11, 2014 | 03:46 AM
GoldOlds94's Avatar
Okay I was thinking it was the stock bumper. Too be street legal you just would need to get a aftermarket light. I would run the positive/Negative by pulling a tail light an tapping into its wires. Make sure it's the running light wires not the turn/stop ones. Or buy a license plate frame that had lights built in.
Old Dec 11, 2014 | 12:31 PM
Radio's Avatar
I didn't know there were frames with lights built in...I think I'll just do that. Thanks man.
DocMcBuff
Sep 28, 2014 10:43 AM
BehaBlazer
Jan 6, 2011 05:06 PM
svd85
Nov 25, 2010 01:46 PM
god_zilla00000
Dec 10, 2009 11:32 AM
chris015
May 2, 2009 02:03 PM
