license plate lights
Old Nov 20, 2015 | 06:50 PM
hylander6361's Avatar
hylander6361 is on a distinguished road
Default license plate lights
hey all,
so another random issue for you, BOTH of my rear license plate lights dont come on. i tried changing the bulbs and that didnt fix it. i dont have any other light issues, but what fuse would this be under? or what other possible issues could this be?
thanks!
Old Nov 20, 2015 | 08:07 PM
richphotos's Avatar
*moved to lighting & electrical*
Please make sure you post your question in the correct sub forum, thank you.
Old Nov 26, 2015 | 11:43 PM
truc.karl's Avatar
truc.karl is on a distinguished road
The fuse is TRL PRK 10a. Don't forget to check the wiring under the truck.
Old Nov 27, 2015 | 08:50 AM
newguy's Avatar
Check the ground wire come from the lights
Old Dec 14, 2015 | 09:33 PM
madmaxxed's Avatar
madmaxxed is on a distinguished road
I eliminated the quick disconnect plug thinking it might have corroded and caused fault connections and tied the grounds and power wires directly. No luck. I then tried grounding the wires directly to the frame and it worked but also keep in mind that you need to make sure the dash sensor is covered to replicate darkness. Also, I cut and capped the two ground wires going to the fuel pump. I'm not sure if those two grounds ran further to provide grounding for those lights.
Philipx
Dec 14, 2015 04:29 PM
pbd3mon
Dec 29, 2007 08:24 PM
Clock72
Mar 4, 2007 05:50 PM
Jhop16
Oct 9, 2006 09:10 PM
16gauge
Oct 17, 2005 12:01 AM
