Light Bar Help
Old Jan 14, 2019 | 08:36 PM
TheZR2ThatCould's Avatar
TheZR2ThatCould is on a distinguished road
Default Light Bar Help
Alrighty Folks. Calling all the help in this one. I have a 42” light bar that I picked up for real cheap. It is straight. Now I have no clue where to mount it without it bottoming it out. The brackets arent tall enough for the hood and it is too wide for my cargo rack (by about 2 inches). Anyone have diy bracket ideas or mounting ideas?
Below is the picture of my blazer.
Old Jan 14, 2019 | 09:17 PM
cleburne red's Avatar
What about on the roof, in front of the roof basket? If the brackets aren't long enough to mount that way, could always use longer bolts with washers or nuts in between the bracket and roof. Might look kinda janky, though
Old Jan 15, 2019 | 12:36 AM
Hess13x's Avatar
I have a 52" curved light bar on my 96. First attempt at mounting it was to build upswept brackets and screwed them directly to the roof. I have since built brackets that screw into the door jam.
I have lowered the light bar another 2" on the brackets since this pic.
Old Jan 15, 2019 | 06:00 AM
Im thinking to do that and mount them to the front of the OEM cross bars at the front of the OEM rack. Thanks!
Old Jan 15, 2019 | 06:01 AM
looks good, do you think I could do it with a straight?
Old Jan 15, 2019 | 10:03 AM
Hess13x's Avatar
You should be able to do the same with a straight bar. You could do the same type of brackets but move them back so the bar is above the roof. You could also get the brackets for a newer k1500 and adapt them to your truck.
Old Jan 15, 2019 | 05:06 PM
Hess13x's Avatar
Also you could flip your exsiexis brackets so they point in instead of out. That might make it narrow enough to fit the roof rack.
hylander6361
May 26, 2019 11:53 PM
hunter270270
Jun 20, 2016 06:51 AM
MyFirstDiesel
Mar 14, 2012 02:14 AM
texas rebal
Dec 6, 2011 11:01 PM
Boyer2011
Nov 11, 2009 12:47 AM
