lights
Old Oct 19, 2014 | 05:53 PM
kenny100034's Avatar
kenny100034 is on a distinguished road
Default lights
Bought new off road lights Friday from Harbor freight and installed them tonight. Finally got everything bolted on and wired and nothing. I checked the fuse and it's OK all of the grounds are attached the only thing I didn't do was ground the switch itself. Will this cause the lights to not work?
Any help would be appreciated
Old Oct 19, 2014 | 07:16 PM
247monster's Avatar
How do you have them wired directly from the battery fuse switch and lights or are you splicing into anything
Old Oct 19, 2014 | 07:23 PM
from the switch one wire to battery with a 20 amp blade fuse. then one to lights with a jumper wire in between and both lights grounded individually. Im wondering if my grounds there are no good.
Old Oct 19, 2014 | 08:14 PM
rexazz2's Avatar
a test light is your friend !!
switch should only need ground if it has a light in it itself
run a temporary ground back from each light to the battery , will test your ground
Old Oct 19, 2014 | 08:38 PM
rexmburns's Avatar
Super Moderator
Chances are you don't have a good ground. You should really look into using a relay.
Old Oct 20, 2014 | 08:13 AM
Thanks for the help. I'll try a different ground when I get home. That's what I was thinking was the issue.
rexmburns I've never ran a relay on any before so I don't know how to go about wiring one into the system.
edavison
Dec 20, 2010 09:55 PM
cjs030901
Jun 7, 2007 08:51 AM
ewingmh
May 13, 2007 07:21 AM
98BlackBlazer
Aug 28, 2006 01:31 AM
rryker
Apr 25, 2006 04:14 PM
