More lights= big 3 or HO alternator? HELP PLease!
Old May 19, 2013 | 09:38 PM
johnjfeher's Avatar
johnjfeher is an unknown quantity at this point
witching i appreciate it i will def be doing the big three regardless. thanks for everyones input!
Old May 19, 2013 | 11:22 PM
WitchingHour's Avatar
WitchingHour is an unknown quantity at this point
Here's the Blue Sea fuse panel I ordered (with the cover removed). I'm probably going to end up installing this somewhere in the cab, since the engine compartment doesn't give me much space, although there is a spot along the firewall where I could put it, I suppose, although it would be a little bit of a pain in the *** to get to if I needed to change a fuse, and I'll mount it with #8 sheetmetal screws.
I plan on running 4AWG from the battery to it, with an inline fuse on the positive side.
Old May 20, 2013 | 06:47 AM
johnjfeher's Avatar
Hey thanks man but I think that's going to be on hold for now just got a new problem, grinding noise from front right wheel, probably wheel bearing or cv joint, and it axle I have no idea and it's really loud. This think is turning into a money pit trying to fix it
Old May 20, 2013 | 07:05 AM
richphotos's Avatar
yikes, check your brakes, noise continue even when brakes applied?
Old May 20, 2013 | 11:52 AM
johnjfeher's Avatar
brand new brakes noise is only when im rolling or when foot is on gas etc.
Old May 20, 2013 | 01:23 PM
tibby's Avatar
Default .
I'd do the big 3 upgrade with an alternator from a full size Chevy (ad244). These two will do the job for you. Plus a used ad244 is a heck of a lot cheaper than a ho alternator. You can find them for around $50 or $60 in pretty good shape. If you're looking for "TRUE" to gauge wiring, get KnuKonceptz wiring from either eBay or from their website. Their 0 gauge wiring is true to size unlike some of the other brands out there. Also, a quick note if you do decide to do the ad244 alternator upgrade. You will need about an inch longer belt than what you have on there now. Just a heads up.
KnuKonceptz website
KnuKonceptz eBay Store
ad244 full size Chevy alternator upgrade
Old May 20, 2013 | 04:21 PM
johnjfeher's Avatar
thanks man im probs going to do the big 3 see how that holds up than go to ad244
bear159
Oct 31, 2013 01:20 AM
ON THA LOW
Oct 5, 2011 08:23 AM
dougs10
Dec 14, 2010 03:24 PM
butters
Sep 29, 2008 06:40 PM
2001blazer
Tires and Wheels
Mar 9, 2006 02:39 PM
