My 2001 Chevy Blazer wont start, just clicks
Old Apr 3, 2012 | 11:47 PM
David Hineline's Avatar
David Hineline is an unknown quantity at this point
If you have 12v at the battery when you hit start and 9 volts at the starter when you hit start, then wiring or connections going through relays or what ever is dropping the voltage is the problem.
Turn on your headlights, start your truck, if the lights dim way down than the battery voltage is dropping, charge it or replace it, or clean the battery connections, if the lights stay bright then the starter is not putting a load on the system due to bad connections to the starter.
Old Apr 4, 2012 | 11:06 AM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
Originally Posted by bowtieboy27
Hey
I know your problem, I'm having the same problem to and I am also a student with my blazer as the only form of transportation. I have an external battery charger that plugs into the cig outlet. That works every time. Just a thought. Good luck!!!
You plug the battery charger into your car, to charge your own car?:S
Old Apr 6, 2012 | 09:39 PM
vladcebes's Avatar
vladcebes is on a distinguished road
Hi all,
I cleaned all of the wires with water and baking soda, it worked!!! But It takes time to start with cranking. I think I have a fuel pump problem too.
Thanks for your replies.
ckrauss
Aug 13, 2016 12:52 PM
gettinbrushless
Aug 13, 2016 12:47 PM
MilwaukeeWoman1
Apr 1, 2012 11:17 AM
AlleyCat
Nov 13, 2011 04:27 PM
ASCOTTH
Oct 3, 2010 09:57 AM
