4 w/d wont engage all the way...clicks/grinds
Old Oct 2, 2010 | 08:04 AM
ASCOTTH's Avatar
ASCOTTH is on a distinguished road
Default 4 w/d wont engage all the way...clicks/grinds
OK....BOUGHT A 99 BLAZER 4X4... New to 4x4 ownership...push the button, I can hear the vacuum switch engage...even went so far as to hook an independent source of vacuum...it pulls/pushes? but does not engage all the way any ideas? 1st time I engaged it after the initial buy..it was in gear then jumped out with a big bang at about 25 mph...since then it hasn't engaged all the way....would like to fix it, hopefully without swapping out the whole thing as my friend/mechanic suggested..... thanx for any help/comments/ideas....s\scott
Old Oct 2, 2010 | 08:31 AM
ASCOTTH's Avatar
update.....pulling in cable to engage front end locking with vise grips grinds/doesnt engage completely....something wrong (obviously) in front end? fixable or new front end? ideas??
Old Oct 3, 2010 | 08:56 AM
CNYCountryKidd's Avatar
CNYCountryKidd is on a distinguished road
How far can you pull the cable with vise grips? I had mine apart yesterday changing the actuator (in which the plunger was bent) and after I put the new one in it only moved maybe 1/4 of an inch.
Old Oct 3, 2010 | 09:13 AM
ASCOTTH's Avatar
[QUOTE=CNYCountryKidd;367542]How far can you pull the cable with vise grips? I had mine apart yesterday changing the actuator (in which the plunger was bent) and after I put the new one in it only moved maybe 1/4 of inch............... I did not do the vise grip thing, my mechanic did....but 1/4" doesn't sound like enough movement to me.
Old Oct 3, 2010 | 09:57 AM
eduncan22's Avatar
eduncan22 is on a distinguished road
Bad transfer case....?
check for leaks on the transfer case...no oil = bad transfer case.
vladcebes
Apr 6, 2012 09:39 PM
AlleyCat
Nov 13, 2011 04:27 PM
BIGGHOWELL
Oct 23, 2010 04:47 PM
Nuzman
Jun 7, 2008 11:37 PM
3D_Illustrator
May 15, 2008 07:56 PM
