Need connector identification
Old Dec 30, 2011 | 09:23 PM
Takwakin's Avatar
Takwakin is on a distinguished road
Question Need connector identification
I own a Chevrolet Blazer 1997 LT 4WD
I was searching for a random trouble on my truck making it stall...when i unplugged a random connector underhood it solved the problem.
1- Fuel gauge needle begun to swing back and forth then jammed past the FULL and keep stuck there.
2- Received a P0107 code Low voltage at map sensor with 2 volts.
3- After disconnecting this random connector the MAP and EGR sensors went back to a 5 volts and the truck started fine, engine run better and fuel needle gauge went back to EMPTY without moving. I suppose its not connected anymore.
Green + Black + Grey + White + Pink
5 wires of that connectors sticked to the driver fender between brake booster and the fender itself.
I removed it from the firewall and unplugged it so can you tell me what is the exact usage and what it feed.
jkyle187
Jan 8, 2015 05:56 PM
wingman1305
Feb 16, 2012 07:54 PM
knightryderx2
Feb 21, 2010 05:58 PM
89Blazze
Engine & Internal
Nov 10, 2005 07:30 PM
88blazer
Engine & Internal
Feb 21, 2005 03:49 AM
