Need electrical help! (Brake lights, 99' blazer)
Old Dec 27, 2020 | 01:54 PM
MissyMonsterTruck's Avatar
MissyMonsterTruck is on a distinguished road
Default Need electrical help! (Brake lights, 99' blazer)
Having a weird issue... left brake light doesn't work- but DOES work when the right turn signal is engaged. Both tail lights work but I loose everything on the left as soon as I touch the brakes (Ecept for the aforementioned turn signal). I thought it might be the sockets since I live on the coast, so I replaced all of them on the left- no luck. All bulbs left and right are new as well. Any suggestions???? If anyone can link a wiring diagram too that would be much appreciated, thanks!!!
Old Dec 30, 2020 | 12:20 PM
Your symptoms remind me of what happens on trailer lights when they lose their ground. To test this, you can use a jumper wire to see if the bulb works correctly if you substitute the ground connection in the socket with a direct connection to clean metal on the body. Or you can use a multimeter between the electrical supply and a good body ground.
dano440
Oct 28, 2017 08:31 AM
mmtilton
Dec 3, 2011 11:30 AM
69ER
Jun 10, 2011 02:39 PM
slickwilly1976
May 15, 2011 02:43 PM
danjkelly
Aug 2, 2009 07:47 PM
