Need help with electrical diag
Yea no problem so the pin that's causing the issue is pin j brown/white wire but I don't have the modular it's referring to witch is the memory seat module not understanding how that's causing my issue with no module?
OK now I understand. Then just disconnect that wire from the comb connector leaving a pigtail from the connector so you can reconnect if needed. That wire may terminate under the seat and has shorted.
George
George
infamousgkc
Jan 4, 2018 05:08 PM
bluextreme02
Nov 18, 2009 07:57 AM
