need help with gas gauge.
Old Feb 1, 2012 | 12:19 PM
Rottidog's Avatar
Originally Posted by patitur77
I have heard that it could be some type of ground that goes under the body of the truck with a bad connection, make any sense of that? If so then where is it located?
If we on the same page about what you're talking about, then it's this page I believe:
https://blazerforum.com/forum/2nd-ge...problem-42968/
Old Feb 1, 2012 | 04:38 PM
metroid_killer@hotmail.com's Avatar
metroid_killer@hotmail.com is on a distinguished road
my fuel gauge quits periodically due to as bad wire (thats been repaired before) it tends to get rubbed by the transmission crossmember and or the shift linkage. Id check there for signs of corrosion and test for voltage to the wires from the fuel pump.
Old Feb 3, 2012 | 05:53 PM
and listen to gatorboy44 ive learned the hardway on spark plugs and fuel pumps spend the extra and get ac delco parts only. there is a reason why they come with these prts from the factory and that is cause ac delco does it best
grayman63
Jul 17, 2013 01:56 PM
98blazerb
Jun 20, 2012 09:53 PM
starandrose
Sep 22, 2010 06:25 PM
dew88
34
Jul 29, 2009 07:55 PM
