Need hlep with charging issues!!
Old Jul 30, 2012 | 08:23 PM
Matt Barrett's Avatar
Matt Barrett is on a distinguished road
Default Need hlep with charging issues!!
I have a 98 blazer and i just replaced my alternator with a new one and the belt and tensioner and now i have an issue where my battery lights on, the volt meter is low and not charging the battery. ive tried a new alternator pigtail, ive had the battery tested and the alternator tested and everything came back god and with the new pigtail everything worked for about 10mins at idle then i went to install new wire loom and all a sudden the battery light pops back on and the volt meter drops back down... im not sure what the deal is or where to go from here, so any help would be appreciated at the point as this is a daily driver for my girlfriend and im racking up the miles on my camaro now driving us both to and from work..
Old Jul 30, 2012 | 08:24 PM
and with all this happening i also lost my license plate lights as well, so i got new bulbs and still nothing
Old Jul 31, 2012 | 12:15 PM
Rottidog's Avatar
I'd check for loose ground connections to & from the engine to the body.
Make sure all your connections are clean & tight.
Old Jul 31, 2012 | 03:38 PM
the DJ's Avatar
the DJ is on a distinguished road
Are you sure yo put the belt on the right way?
Old Jul 31, 2012 | 05:48 PM
yes the belt is on right...
Old Jul 31, 2012 | 06:29 PM
Rottidog's Avatar
Kinda hard not to if you want everything to run. With mine it's even more confusing with the supercharger being driven. But IF it's possible I can see his point by the alternator running bassackwards.
Old May 7, 2013 | 07:13 AM
i know its been a while, but come to find out it was the altnator the whole time.
Old May 8, 2013 | 03:29 AM
the DJ's Avatar
But you mentioned it was tested?
Old May 8, 2013 | 09:23 PM
cleburne red's Avatar
So the new alternator that you had tested turned out to be bad? What's the story behind that?
Motocross16
Aug 2, 2011 07:44 PM
buffalorider13
16
Feb 5, 2011 07:43 PM
Idaho Mike
Apr 5, 2010 06:22 AM
odfareal
Nitrous, Super Chargers, & Turbos
Oct 26, 2009 01:36 PM
wwwben
Oct 14, 2007 09:47 AM
