New Battery question
Old Mar 10, 2013 | 07:12 AM
okiedoak20's Avatar
Default New Battery question
Ok , im looking to get a new battery for my 2000 jimmy, it calls for a series 75, and i can find it with 500-700 CCA (cold cranking amps), but in the older Blazer/Jimmy's the series 78 battery is called for and i have seen those with 800+ CCA, so can a series 78 battery fit in a 2000 jimmy...
I know the physical wire connections will work, side mount, but will it fit size wise. I can go with a Optima Red Yellow or Blue, but the price is,well out of my price range, and i can get the series 78 Excide battery from Costco/BJ's for under $100 bucks, see where im going with this???
Old Mar 10, 2013 | 07:01 PM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
x2 on this but if no one says I would go to Costco, and ask if you can return it if it does not fit in the space. Then check it in the parking lot. I would guesstimate there would be room for a battery to be 1/2in more depth(front to back of truck) then 1-1 1/2in wider, and maybe 1 taller.
Old Mar 10, 2013 | 10:41 PM
zball94's Avatar
zball94 is an unknown quantity at this point
I bought my new battery based on dimensions alone and it has 7xx CCA, and it starts fine in -30 degree weather.
1998mom
Jul 25, 2013 09:43 AM
TigaHotty85
Jun 17, 2013 03:10 PM
chevyman93
Dec 17, 2012 05:59 PM
tnw912
Jan 5, 2010 05:27 PM
Argo123
Oct 21, 2008 09:28 PM
