New HID's
Old Nov 27, 2010 | 11:51 PM
  #21
streblo's Avatar
OK...so this is what i found on the quad beam. and yes it works with dual HIDS.
You only need to do this on ONE bulb (At least all i had to do anyways), i chose my driver side.
-SPLICE into the yellow wire coming from the low beam bulb(9006). NOT the yellow/black wire.
-Run that wire to ground.
-DONE, you now have quad beams
What i did is i ran a wire that i spliced in to a switch that i mounted on the dash so that i can turn the quad beams on and off, i used a simple in and out switch, then ran the wire coming off the switch to a ground under the dash. (I tried using a switch that had illumination (so 3 wires, one in, one ground, one for illum) but it DID NOT WORK, i have no idea why). If you dont want a switch you can just ground it to anywhere. I am to understand this only works on 2nd gen.
I got the info from this thread when i did mine
https://blazerforum.com/forum/showth...ight=quad+beam
Old Nov 28, 2010 | 02:37 PM
  #22
zedartwo's Avatar
You only have to do it to one side?
EDIT: DONE! It was easy!
Old Nov 28, 2010 | 04:16 PM
  #23
streblo's Avatar
Haha yes.
DONE: it was easy.
And yes i only had to splice into the yellow wire on ONE side, i did the drivers side
Old Nov 28, 2010 | 04:26 PM
  #24
Brianator99's Avatar
Brianator99 is an unknown quantity at this point
Alright awesome! Thanks for the info. I read that same thing a million times but people had so many ways that it could be done I didn't want to pick that one bad way lol
Old Nov 28, 2010 | 04:35 PM
  #25
zedartwo's Avatar
I had to do both. did you ground both ends behinf the drivers or just the one coming from the light?
Old Nov 28, 2010 | 07:25 PM
  #26
streblo's Avatar
just spliced into the one yellow wire, about 2 inches away from the low beam bulb and only on the one side....................weird..maybe has something to do with the different wiring for the zr2 as kyle said earlier....but then again yours is a zr2 as well, are your low beams drls?
Old Nov 28, 2010 | 08:21 PM
  #27
zedartwo's Avatar
Yup. Maybe its got something to do with being Jimmy. Only made for Canada = different standards.
Old Nov 28, 2010 | 10:36 PM
  #28
streblo's Avatar
huh weird, would be interesting to compare the wiring diagram from the jimmy to the blazer and see what if anything is different.
Old Jan 21, 2012 | 09:00 AM
  #29
BLAZER97LS's Avatar
BLAZER97LS is on a distinguished road
Where did you get your headlights??
Old Jan 21, 2012 | 05:48 PM
  #30
streblo's Avatar
Headlight housing was off ebay
LuvMyTJ
Apr 22, 2010 09:59 PM
Jfutch101
Dec 22, 2009 04:38 PM
cr8390
Dec 25, 2008 01:44 PM
jagblazer01
Mar 9, 2006 10:43 PM
blue_green_rider
Feb 7, 2006 10:44 AM
