No Electrical power anywhere
Old Mar 18, 2016 | 11:11 PM
Chlorin8ed's Avatar
Chlorin8ed is on a distinguished road
Default No Electrical power anywhere
My daughter got into her 98 blazer. Dome lights came on, she adjusted her electric seat, etc. Key in the ignition, turn it, lights lite up and EVERYTHING went dead. No lights, no power any where....
I didn't take a volt meter out to it yet, but my 12v light lights up at the battery. I tried to see if there is power to the under hood fuse block. It does not seem to have power there at the stud. None of the fuses (ignition) are blown. Is there an inline fuse or relay between the battery and the fuse block? Any other suggestions or ideas?
Old Mar 19, 2016 | 05:28 AM
donald_archer's Avatar
donald_archer is on a distinguished road
I have a 98 with a side post battery. Same thing happens to me.One of my Blazer's little quirks is that especially during cold weather the negative battery terminal kind of loosens up on its own. Happened to me 2x this winter. Not loose enough to come off or anything just enough to cause a problem. Check the 2 terminals while you are at it it is an easy fix.
Old Mar 19, 2016 | 07:47 AM
Chlorin8ed's Avatar
Thanks Archer... i am pretty sure that is not the problem. But it never hurts to double check....
I dd read something about a mega fuse: but can not find out any info on replacement or where you can buy it, if that is the problem. Can anyone shed a lite on a mega fuse???
Old Mar 19, 2016 | 08:23 AM
Under the battery tray is a 175 amp Mega Fuse. Everything electrical goes through the fuse, with one exception: the main starter cable is not fused. The fuse holder can corrode and grow some nice green fuzzies on it. Remove the battery and the tray, take the fuse out and clean the connections.
Old Mar 19, 2016 | 02:11 PM
Chlorin8ed's Avatar
thanks for info Hook, never heard of that.
But I fixed it. Archer was very close. The negative cable bolt was cross threaded, so when I wiggle it, it was tight, then all of sudden it was loose. Thanks everyone
Old Mar 19, 2016 | 02:15 PM
Ahhh yes, that would do it! Good job, thanks for posting back. Might not be a bad idea to at least check the Mega Fuse. A crappy connection there could leave your daughter stranded too
Blazer Kid
Jul 5, 2015 11:35 PM
DaddysBlazer
Apr 1, 2012 06:37 PM
caprini83
Apr 13, 2011 06:31 PM
CNYCountryKidd
May 24, 2010 06:15 AM
quik1964
Feb 18, 2009 09:42 AM
