No interior ligting
Old Nov 12, 2013 | 11:54 AM
blazefan's Avatar
blazefan is on a distinguished road
Default No interior ligting
I have a 2000 blazer and when I open the doors the inside lights do not come on. I can override them to confirm the bulbs are working...and when I press the remote unlock they come on?? Also, the radio goes off when I turn the key off (it usually stays on for a short time)
Any ideas on this?
Old Nov 12, 2013 | 01:47 PM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default bad door switch
Look to the door position switch.
Old Nov 12, 2013 | 11:21 PM
TorqueJX's Avatar
TorqueJX is on a distinguished road
i believe that it may be one of the buttons that are located on the doors when you close the door the button opens the circuit turning the lights off and when you open the door the circuit closes turning the lights on one of those buttons may not be working anymore and when this happens the lights go on and off but not anymore by these door buttons because the lights go off after a certain amount of time when you have the doors open you could try checking those switches use the remote and make the lights go on and try opening or closing the doors they should go off the moment you close the door and it they don't it may be because the switch on #? door is not working you could try that... hope this helps...
2oooBlazer
Nov 17, 2009 08:09 PM
Dutch_EXP
May 3, 2009 01:09 PM
zero psi
Nov 13, 2005 04:07 AM
Biohazrd
Sep 13, 2004 10:43 PM
drewminator33
Sep 1, 2004 12:00 PM
