no power
Old Aug 21, 2013 | 06:20 PM
jasaon's Avatar
jasaon is on a distinguished road
Default no power
i got power to starter from battery but no power to s terminal on on starter this wire rums together with other wires wrapped up as one to kept from undoing the wrapping can anyone tell me where this wire comes from to help isolate problem thanks.
Old Aug 21, 2013 | 07:17 PM
rexazz2's Avatar
fusable link would be my guess
GM has used them at the starter for years and they sometimes will burn for no reason
or was there a ground strap that you left off when changing the tranny ?
Old Aug 21, 2013 | 07:41 PM
richphotos's Avatar
If it worked before tranny change. Check and double all grounds. That would be guess before fuseable link. Fuseable link would be second
Old Aug 21, 2013 | 07:55 PM
rexazz2's Avatar
a quick ground check , booster cable jump from battery negative to engine block and engine block to body
Old Aug 23, 2013 | 03:27 PM
jasaon's Avatar
truck ran fine for two weeks everything on trans seems to be hooked up fine by fuseable link you mean the fuse under the battery?
flipzat
Dec 2, 2009 04:05 PM
fresno99
Jul 31, 2009 08:12 PM
1991whiteoutblazer
Jan 8, 2009 08:17 PM
nate2003456
Jan 18, 2007 01:10 AM
freeman
Aug 23, 2005 10:55 PM
