No power after attempted crank. 2001 zr2 blazer
Old Nov 6, 2020 | 05:20 AM
Chase Clouser's Avatar
Chase Clouser is on a distinguished road
Default No power after attempted crank. 2001 zr2 blazer
I can open the door and have interior light , put the key in the ignition turn to accessory and dash lights come on as do the headlights. But as soon as I go to turn the key to start everything goes dark, not even a click from the starter, and won't come back on when key is cycled it has to sit for a bit before the lights will come back on inside . I'm not even remotely good at wiring thats why I'm here asking for some guidance. Oh yeah and battery is new it has 12.7 volts at the terminals.
Old Nov 6, 2020 | 08:26 AM
That sounds like a bad battery cable connection. Check both ends of all battery cables (positive and negative). You can also have somebody else try to crank it while you watch for sparks.
Lunchbox12387
Nov 13, 2017 03:28 AM
Daniel Wakefield
Aug 6, 2013 02:02 PM
Ranic85
Nov 30, 2011 09:05 PM
PatsZR2
May 9, 2011 09:50 AM
ejradel
Jul 5, 2006 01:10 AM
