no power to ignition or cluster
I have a 1999 Blazer 4x4, there was recently a hurricane and it ended up being flooded, I pulled plugs drained all fluids out of everything including full tank of gas and the was trying to get the truck to start and it would turn over start and run rough, after a few tries of getting it to run after getting everything back together and new fluids in letting it dry out for two days it no longer has power to the ignition or dash cluster, my airbag light is the only thing that's will come on on the cluster. radio dome lights windows door locks headlights etc all work but it will not turn over ignition does nothing and dash does nothing. I've swapped the ignition switch checked all fuses swapped main Fues under the battery and still nothing. pass lock shouldn't have anything to do with it right?
the water was about ankle deep on the driver floorboard, and the ignition is still turning on the headlights but does not engage or disengage anything else throughout the truck, the temp and fuel gauge are the only things aside from headlights that do anything at all when I turn the key on or try to turn it over.
I was kind of leaning towards the pass lock box because off it being right on top of the transmission tunnel it could've gotten water to it but that should only cut power to the fuel pump from what I remember.
George
George
EN_01
08-19-2021 09:35 PM
shadetreeauto
07-01-2013 10:59 PM
riotousness
07-15-2010 05:41 PM
BlackFireLS4.3
01-29-2010 10:00 PM
