No Radio with Key in Accessory Position
Old Dec 14, 2019 | 08:22 AM
Blazer112's Avatar
Blazer112 is on a distinguished road
Default No Radio with Key in Accessory Position
Hello,
I have an 04 Blazer Zr2 which has undergone a mini-restoration using nothing but OEM parts. The following problem was evident prior to and after the work.
The radio will not function with the key in the accessory position or under the Reserve Accessory Power (RAP) system offered by the truck. I have tried the following without result:
all fuses/relays checked both in cab and under the hood
new GM OEM ignition switch
All other (required) items work with key in accessory position (windows, wipers)
RAP (reserve accessory power) functions perfectly for all other necessitated items except the radio.
My next step is to pull the radio and check what I assume is a unique wire used to power the radio under both “key in accessory position” or “RAP” circumstances which research shows to be dark green in color.
I have the feeling there is a fuse I am missing or a wire connector left unplugged that feeds the radio in these two circumstances directly from the battery. However, automotive wiring is tricky, to say the least, and I thought someone else may have suffered from this same issue so any help would be appreciated.
The radio only works while the vehicle is running.
thank you
carpboy
Sep 17, 2017 06:58 AM
Jimmy_Blazer
Dec 27, 2015 09:58 AM
Prozon
Jan 26, 2014 06:51 PM
Rrryan
Aug 15, 2011 12:03 PM
Scuba65
Dec 13, 2006 07:33 PM
