Obd 1.5 paperclip trick?
Old Aug 21, 2017 | 06:45 AM
Tynan Tha Real Dill's Avatar
Tynan Tha Real Dill is on a distinguished road
Default Obd 1.5 paperclip trick?
I have a 95 with the 16 pin obd 1.5 connector. Can't get it tested anywhere. Seen and read about a paperclip trick on OBD1 and the check engine light flashes you the trouble codes. Can this be done on OBD 1.5 too?
Old Aug 21, 2017 | 10:22 AM
Rusty Nuts's Avatar
Yes. The paper clip goes to pins 4 and 6 of the OBD port. Turn the key to run. It will flash code 12 three times to show it's operating correctly then flash the trouble code.
Old Aug 21, 2017 | 10:28 AM
Ok... This is probably a dumb question, but the only paper clip I have is painted, do I only need the tips cleared of paint or the whole thing?
Old Aug 21, 2017 | 10:31 AM
Rusty Nuts's Avatar
Definitely scrape the paint off to make sure you get a good connection. Remember always, loose wires make fires.
Old Aug 21, 2017 | 10:36 AM
Mine doesn't have a wire in #6 pin...
Old Aug 21, 2017 | 10:40 AM
Rusty Nuts's Avatar
Got a pic?
Old Aug 21, 2017 | 10:44 AM
Rusty Nuts's Avatar
Start at the upper left and count to the right.
Old Aug 21, 2017 | 10:50 AM
Got a pic?
Here you go
Attached Thumbnails Obd 1.5 paperclip trick?-20170820_195955.jpg   Obd 1.5 paperclip trick?-20170821_104343.jpg
Old Aug 21, 2017 | 10:52 AM
Or maybe the color of the wire for diagnostics pin ?
Old Aug 21, 2017 | 11:07 AM
Only 2,4,5,9,13,16 are used and have wires attached to them
