Obd 1.5 paperclip trick?
Old Aug 21, 2017 | 11:07 AM
Rusty Nuts's Avatar
The solid black wire (no white stripe) is the ground and the purple wire is the data feed.
Old Aug 21, 2017 | 11:12 AM
Rusty Nuts's Avatar
Place the jumper wire in pin 2 and 4
Old Aug 21, 2017 | 11:15 AM
Tynan Tha Real Dill's Avatar
Tynan Tha Real Dill is on a distinguished road
Still isn't flashing, check engine light just stays on. What is pin 16 ? I grounded that pin with the paper clip, it popped and the paper clip got hot.
Old Aug 21, 2017 | 11:19 AM
Can a low battery have an effect?
Old Aug 21, 2017 | 11:30 AM
Rusty Nuts's Avatar
Sorry for the wrong info. That's the thing with 95. I usually don't answer about them because they prove me wrong.
Old Aug 21, 2017 | 11:39 AM
Rusty Nuts's Avatar
I don't know which orange wire is in pin 16. Why you grounded it doesn't matter now. Yes, 12 volts is required for testing. Put the battery on a charger and start checking all your fuses. Sniff around for anything burned.
Old Aug 21, 2017 | 12:38 PM
Rusty Nuts's Avatar
I was off on the original pin location, not the wire color. You're toasting things faster than I can double check my answers and post them.
Old Aug 21, 2017 | 02:31 PM
Rusty Nuts's Avatar
Your dedication, hard work, willingness to learn is admirable. You've proven yourself as "tha real". I'm a fan.
Respectfully, when you're not sure about something, please stop. You're dealing with very dangerous situations. Wet cell batteries can explode, blowing acid everywhere. Electrical problems can catch fire. Put them around fuel and adding starting fluid into the mix increases the risk exponentially.
I don't want to start a thread on this. But everybody has a story of educated experienced technicians hurting themselves. I have 9 and 1/2 fingers.
Old Aug 22, 2017 | 03:59 AM
Ur right, I toasted my battery! Won't even take a charge now.
Old Aug 22, 2017 | 04:33 AM
Rusty Nuts's Avatar
The orange wire in pin 16 is usually the power feed that's 12 v. at all times. Now we know for sure. Sorry to hear that autozone sold you another defective battery. Good thing it's under warranty.
