One Rear Power Door Lock Will Not Work.
Old Feb 27, 2012 | 07:06 PM
bowtie-72's Avatar
bowtie-72 is on a distinguished road
Default One Rear Power Door Lock Will Not Work.
I have a `94 s-10 Blazer 4-door Tahoe LT. The left rear power door lock quit working and I was so sure that it was the door lock solenoid that I went to the bone yard and pulled one. ( I know, I know, I did not want to pull the door panel twice.) When I put it on it still did not work so I checked the power and sure enough, no power to the solenoid. The right side works fine. I was wondering if someone else had this same problem and where you found your power break at? Thanks.
Old Feb 27, 2012 | 09:24 PM
warthogdriver's Avatar
Check the ground on the harness at the motor...or check the switch for corrosion.
I once had to re ground a door solenoid...original had a break in the wire
Old Sep 3, 2012 | 08:07 PM
bowtie-72's Avatar
OK. Here is a long overdue update. I pulled the inner panel on the door post ( this is where the door wireing harness pluges in ) and found that I had power going to the door. So I ran an Ohmes test back thru both wires for the door lock ( the gray wire and the biege wire ) and found that I had a break in the biege wire. Now all I have to do is replace/bypass that wire and that should fix the problem. I hope this helps someone.
Chase_S
Sep 11, 2013 10:25 PM
BlueDSM
Aug 11, 2010 05:05 PM
ussexplorer
Apr 16, 2010 04:49 PM
ussexplorer
Apr 4, 2010 08:39 PM
rossg
May 27, 2009 07:48 AM
