Plug scanner but nothing happens???
Old May 17, 2013 | 08:01 PM
twowheels012's Avatar
twowheels012 is on a distinguished road
Default Plug scanner but nothing happens???
Hello there, just got this 2001 Xtreme with 4.3, engine light is on but when I plug my scanner, is not showing anything, not even turning on. Any clue? Thanks.
Old May 17, 2013 | 08:30 PM
cferry7's Avatar
cferry7 is on a distinguished road
Default OBDII Connector
OBD-II diagnostic connector
Connector
The OBD-II specification provides for a standardized hardware interface—the female 16-pin (2x8) J1962 connector. Unlike the OBD-I connector, which was sometimes found under the hood of the vehicle, the OBD-II connector is required to be within 2 feet (0.61 m) of the steering wheel (unless an exemption is applied for by the manufacturer, in which case it is still somewhere within reach of the driver). SAE J1962 defines the pinout of the connector as:
1. Manufacturer discretion. GM: J2411 GMLAN/SWC/Single-Wire CAN. VW/Audi: Switched +12 to tell a scan tool whether the ignition is on.
2. Bus positive Line of SAE-J1850 PWM and SAE-1850 VPW 10. Bus negative Line of SAE-J1850 PWM only (not SAE-1850 VPW) 3. Ford DCL(+) Argentina, Brazil (pre OBD-II) 1997-2000, USA, Europe, etc. Chrysler CCD Bus(+) 11. Ford DCL(-) Argentina, Brazil (pre OBD-II) 1997-2000, USA, Europe, etc. Chrysler CCD Bus(-) 4. Chassis ground 5. Signal ground 6. CAN high (ISO 15765-4 and SAE-J2284) 14. CAN low (ISO 15765-4 and SAE-J2284) 7. K line of ISO 9141-2 and ISO 14230-4 15. L line of ISO 9141-2 and ISO 14230-4 8. - Manufacturer discretion. Many BMWs: A second K-Line for non OBD-II (Body/Chassis/Infotainment) systems.
16. Battery voltage
PINS 1-16 Listed Above in Bold. Pins 9, 12, 13 Not Used.
Old May 17, 2013 | 11:08 PM
cleburne red's Avatar
I think there is a fuse for the OBD connector. I know on older 2nd gens, it's on the same circuit as the cigarette lighter. If the fuse is blown, the connector won't be powered.
Also, have you tried a different scanner? Maybe the fault lies with it?
Old May 18, 2013 | 11:11 AM
xfact0r3's Avatar
xfact0r3 is on a distinguished road
Check the cigarette lighter fuse. It happened on me, replaced it and it works fine
Old May 19, 2013 | 07:52 AM
Default Thank You, Thank You, Thank You!!!
Thank you guys, cigarette lighter itself is bad, after I looked for short in wire or some crazy connection from previous owner find out that the lighter is short, I don't smoke so I throw it away. Thanks again.
HBWill
Feb 14, 2014 12:13 PM
morpho18
Nov 12, 2013 06:45 AM
dseanp
Oct 26, 2013 01:45 PM
Droidster
Apr 26, 2013 03:04 PM
Irish10Hockey
Dec 4, 2008 12:48 PM
