Power Side View Mirror Wiring Problem
Old Nov 21, 2010 | 01:04 PM
widmer31's Avatar
widmer31 is on a distinguished road
Default Power Side View Mirror Wiring Problem
I have a 1997 Blazer LT and neither side view power mirror would work. I replaced the control switch and that did not fix it. When checking the power window wiring with an ohm meter I found an open circuit in the orange power wire. Inline from the main door harness to the control switch connector was a thick, heat shrink wrapped part of the harness. I am 99 percent sure that this is factory and not someone else’s handy work. I cut away the shrink wrap (as pictured) and found a very small circuit board with two green diodes/resistor, or at least that’s what I think they are. One of the green resistors was open and needed replaced. Radio shack could identify what the green resistor was so I could not buy a replacement. I went to the u pick it yard and was going to cut one out of a harness, the strange thing is that none of the 4 dr blazers (same year and well as 96’s and 98’s) with power side view mirrors had the heat shrink board as part of the harness, the brown and orange wires went directly from the main door harness to the control switch connector. Not sure if anyone has seen something like this. I was thinking to cut the board out and wire it direct like all the ones I observed at the salvage yard but I am a little concerned about doing that because I would assume that GM did this for a reason. Any help would be appreciated. Thanks
Old Dec 10, 2010 | 12:20 AM
stlwaco's Avatar
stlwaco is on a distinguished road
I would just remove the board and wire the harness together.
Wexinlo
Apr 6, 2011 11:35 PM
BuddyS
Mar 28, 2011 04:46 AM
Cassus Kagal
Jan 15, 2010 09:59 PM
fastpitch321
Dec 18, 2006 07:40 PM
keldog24141
Nov 18, 2006 12:54 PM
