problem with blinkers and 4x4 module
Old Aug 24, 2012 | 03:50 PM
BlackcombJimmy's Avatar
BlackcombJimmy is on a distinguished road
Default problem with blinkers and 4x4 module
hi i got a 2000 jimmy fully loaded whistler edition. my left blinkers blink twice as fast as my right ones. my truck came with towing wiring maybe this is shorting it out? anyone else have the same problem?
also my 4x4 switch should always say 2wd hi when i dont use it, sometimes that button doesent light up i have to press it 2 times to get it lit. whats with that
Old Aug 24, 2012 | 07:20 PM
Blazer_LT's Avatar
Blazer_LT is on a distinguished road
go around and check all the light bulbs, and all the fuses on the blinker issue. i cannot answer your 4x4 light question
Old Aug 24, 2012 | 07:50 PM
Jase1979's Avatar
Jase1979 is on a distinguished road
My 2wd indicator light was going out once and awhile also, I removed the switch and found that the connector on the switch had a bad connection, tighten up the connections and all is good now
jonlandeinthemud
Jun 8, 2011 10:09 PM
ShagMan
May 21, 2010 05:52 AM
jjrowan
Jan 24, 2009 06:23 PM
ccajun4real
Nov 5, 2007 01:07 PM
athens61
Nov 28, 2006 10:24 PM
