Question on cranking engine over
Old Apr 20, 2013 | 06:11 PM
  #21
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Im going to see if I can get a pic of these wires out of camera to see if thse go to the battery or altenator.
Old Apr 20, 2013 | 06:33 PM
  #22
Ok If you see the 2 red wires into 1 terminal I hooked up 12 volts positive and a 12 volt ground.With the key shut off my lights,security system and dash lights all came on.Now should these be hooked up to the battery or altenator?If its the battery they wont reach.
Old Apr 20, 2013 | 07:17 PM
  #23
Those are two of the fusible links that go to the alternator, should be one more around there somewhere.
EDIT: They both appear to be the same gauge wire, if that's right, one of them goes to battery positive and the other goes to the junction block. The third, (smaller gauge) wire, the one that's missing, goes to the starter relay, which I believe is visible on the firewall.
Old Apr 21, 2013 | 09:04 AM
  #24
Im almost certain the go to the altenator,That part of the harness will not move any further forward.I tryed.I put the altenator on the bracket and they barely reach the altenator cause the bracket for it is disconnectd from the engine.
Old Apr 21, 2013 | 03:42 PM
  #25
Default Good news
Got the engine to crankover
The 2 wrie terminal isnt going to the batery unless I lengthen it.Theres noway now how it will reach.Im assuming it goes with the other wire to the altenator.Anyways with power to it I can go inside with the key and turn the engine over.I was also right about the nuetral safety switch not being plugged in.Im still confused why this wire if its supposed to be on the battery why it wont reach?I tryed steching the harness and it pulled the elctrical connection my fuel injection unit.It 6 inches short of the battery.
Old Apr 21, 2013 | 04:37 PM
  #26
The wires in your image go to the rear of the alternator, not the battery. There is one more wire that also attaches to the alternator.
My "edit" was not clear, sorry... the other end of one of those goes to the battery positive. The other end of the other wire goes to the junction block.
Old Apr 21, 2013 | 09:05 PM
  #27
Smile
Ok that would make sense I had the 2 of them in my hand today. Thanks Capatain.Nice to finaly make some progress.Now theres a small groundwire that comes from coresupport goes to the negative side.Keeps coming apart so Im going soilder it and then wrap with electrical tape.
Old Apr 22, 2013 | 07:20 AM
  #28
greencactus3's Avatar
greencactus3 is on a distinguished road
if it keeps coming apart, replace it. the wire is mot likely corroded pretty bad
Old Apr 22, 2013 | 11:44 AM
  #29
Naw its not that,theres a connector one of those kind that you crimp 2 wires together.The yellow crimper just isnt holding the wires.I have to replace that or like soilder them together.
Old Apr 22, 2013 | 12:27 PM
  #30
richphotos's Avatar
solder and heat shrink, electrical tape sucks.
