Question on cranking engine over
Old Apr 22, 2013 | 02:42 PM
  #31
^^^ Yup, crimp connectors have no place on a vehicle, unless you solder the wires to the terminal and use heat shrink tube to seal out moisture. 60/40 lead tin rosin core solder ONLY.
Old Apr 22, 2013 | 04:44 PM
  #32
richphotos's Avatar
I have moved away from lead tin solder, I use lead free rosin core, works amazing. which reminds me, I have to pull the tail lights and put some dialect grease on the quick connects I made.
Old Apr 22, 2013 | 05:01 PM
  #33
Interesting.... lead tin solder has been around for 60 years and has always worked fine. EPA must have stepped in cuz some tree hugger group was complaining about the lead. Hmm, what about the mercury in the CFL bulbs from China that we have to buy?
Old Apr 28, 2013 | 10:58 AM
  #34
watertrucker's Avatar
watertrucker is on a distinguished road
Check your ground cable fom the battery. Had the same problem. Make sure it is connected to engine block or frame. Also has to be clean and tight.I found that AFTER changing stater solenoid & positive cabe.
Old Apr 29, 2013 | 11:00 AM
  #35
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
I actualy tryed the flux core first with bad results,I couldnt get it to flow.Luckily I had lead tin solder which worked.
1998mom
Jul 30, 2013 12:03 AM
yoshiaka13
Jun 1, 2012 11:04 AM
deekisses
May 17, 2012 11:31 AM
Track Slut
Apr 17, 2011 02:24 PM
