Radio blinking.
Old Dec 22, 2015 | 03:37 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default Radio blinking.
2000 Bravada, I got it from my buddy and he hard wired an aftermarket radio in it but kept it and gave me the old radio but not the harness that goes with it... Anyway I got a new harness and am attempting to rewire it back correctly. Power is orange, ground is black, and ignition is dark green. Well I wired these three together just to test it and the clock and radio display just blinks the time or station. I hooked the radio ignition wire to constant power and it stays on fine. Fuses are fine and I tried unplugging the battery and letting it set but still the same issue. Help please?
Old Dec 22, 2015 | 05:59 PM
odat's Avatar
hook it back up the way it should be and try setting the clock and maybe a station or two
Old Dec 22, 2015 | 08:00 PM
I did, the clock only blinks too and I have to push a button within the milisecond that it's on but it it turns off too fast to change anything. I can switch between stations and that it.
Old Dec 23, 2015 | 08:29 AM
Toocute350's Avatar
Toocute350 is on a distinguished road
You may want to check and make sure that the ground wire is secured properly.
Old Dec 23, 2015 | 11:22 AM
Bejaran's Avatar
Bejaran is on a distinguished road
How do I make my own post?
Old Dec 23, 2015 | 11:20 PM
Toocute350's Avatar
Simple..You have to place your question on the right topic.Click that topic then start typing.When I`m talking about topic, I meant is it an electrical problem, motor problem etc..each problem you have will fall under a different category.I was like you when I too was a newbie.As time passes the more you learn
Old Dec 27, 2015 | 09:58 AM
Ground is fine, like I said I hooked the ignition wire right to the live wire and it stayed on fine, when hooked to the ignition wire it would only blink on and off every couple seconds.
Boiler20
Oct 19, 2013 03:53 PM
dan_t
Nov 25, 2010 08:35 PM
iamchevyman5
Nov 7, 2010 01:20 AM
black19
Jun 22, 2006 03:35 PM
