Random plugs under drivers side dash.
Old Oct 12, 2011 | 01:33 AM
Thogert's Avatar
Angry Random plugs under drivers side dash.
Ok so I was looking for wires to try to fix my electrical issues, and I found like 4 plugs under my dash on the left side of the steering columb that wern't plugged into anything! (not including the key fob proggraming plug and the OBDII port) I would like to know wether or not anything is supposed to be plugged in. I looked for anything that was missing a plug and couldn't find anything.
I also noticed that a couple of wires going to some of the plugs were cut. WTH I'm really starting to hate hate hate, the PO.
Sorry, every time I look I see more problems.
Ok so here is the first two I found. These are the ones that have some wires cut off of them. You can see some cut right at the plug, and there are some more further down the wires in the next pic.
The plugs here also are connected to two 20amp fuses. WTH? Why arn't these fuses in the fuse box where they are supposed to be? (BTW I checked the fuses and they are not blown.)
I notticed that some of the wires go to this box and to the fuse box.
Some of the wires go to this cluster right next to the steering columb.
Ok then right next to that cluster were a couple MORE plugs that wern't attached to anything but air.
So correct me if Im wrong, but plugs are generally supposed to be plugged into something. Help me please.
Old Oct 12, 2011 | 06:56 AM
The TRW box is your RKE (remote keyless entry) receiver. The connector that is plugged in with a bolt in the middle of it is the main ignition harness. Those first few pictures are aftermarket wiring originally for an alarm or car starter.
Those last few look factory, but might have been for an option your truck didn't originally come equiped with.
Old Oct 12, 2011 | 03:49 PM
Thogert's Avatar
Ok sweet, thanks again.
blazen_red_4x4
May 9, 2014 12:44 PM
crusemm
Dec 7, 2011 04:34 PM
Wexinlo
Apr 6, 2011 11:35 PM
Monkeyman
Nov 8, 2009 07:51 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
