Rear window defogger- has power but no workie
Old Jan 26, 2015 | 07:06 AM
dhud64's Avatar
dhud64 is on a distinguished road
Default Rear window defogger- has power but no workie
We have had some frost lately and I noticed the rear defogger isn't working on my 99 TB. This weekend I checked for power with a test light and it does have power at the wires on both sides and across all the little wires/elements across the glass. How can it NOT be defrosting? Could it be low voltage? I guess I need to get a multi-meter...
Also, I don't think the heated mirrors are working either, but haven't looked into those yet. I know they have the switch in common, anything else to look for?
Old Feb 11, 2015 | 05:03 PM
If you have voltage on both wires, the ground is open, (broken wire, broken terminal, etc). Unplug both wires, ignition in the run position, turn on the defroster. One wire should show battery voltage, the other wire should show less than 5 ohms resistance to ground.
Old Feb 14, 2015 | 09:35 AM
dhud64's Avatar
Thanks Captain. Diagnosing electrical stuff is definitely a weakness for me!
I got a new test meter and disconnected both wires. I had 11.7 Volts on the drivers side wire (and across the grid when that wire is connected).
Where I'm currently stuck is the display on my meter when trying to check the resistance on the other wire. With both wires still disconnected, I put the red lead on the passenger side wire and the black lead to a good ground; my display doesn't change and reads O.L which appears to indicate over range (pic below). However the meter is supposed to "auto" measure 0 to 20M. I did switch to the continuity function with leads in same position and at least I did not have continuity that way!
I'll continue to tinker with my meter and see what I can figure out.
Attached Thumbnails Rear window defogger- has power but no workie-20150214_091413.jpg
Old Feb 14, 2015 | 02:19 PM
Disconnect both wires from the grid. Connect the black DVOM probe to a good clean ground, no paint, no rust. Ignition in the RUN position, and defroster turned on. DVOM on DC volt range: Red probe to one wire must show battery voltage. The other wire should show zero volts. DVOM on ohms range: Red probe to the zero volt wire must show less than 5 ohms resistance. That's the one I suspect has a problem, in which case, your DVOM will read OL, meaning a bad ground on that wire. Follow it to ground and repair it, or splice on a new piece of wire and attach it to ground.
Old Feb 14, 2015 | 03:32 PM
dhud64's Avatar
Sounds like a plan. Thank you!
Old Feb 15, 2015 | 05:37 PM
dhud64's Avatar
Decided to just splice a ground wire in and now have a reading of 3.XX ohms. Am anxious to try it out now!
Old Feb 15, 2015 | 07:08 PM
What are you waiting for? Flip the switch and feel the glass after a couple of minutes.
Old Feb 17, 2015 | 12:23 PM
dhud64's Avatar
Yeah, I tried that day but couldn't feel any heat. got to try it today in real weather, and it works! You are the man!!!
Attached Thumbnails Rear window defogger- has power but no workie-20150217_085117.jpg
Old Feb 17, 2015 | 06:39 PM
Good job. Thanks for posting back.
vendo
Dec 23, 2014 08:12 PM
Coinhunter
Jul 7, 2013 08:34 PM
richphotos
Oct 19, 2012 05:16 PM
radiorara
Jan 20, 2012 08:59 PM
tscott
Oct 26, 2009 09:23 PM
