Rear window switch help!!!
Old Feb 13, 2012 | 02:48 AM
91blazer91's Avatar
91blazer91 is on a distinguished road
Exclamation Rear window switch help!!!
ok i have a 91 chevy s10 blazer that has all the optional accessories. Im not sure if im doing this correctly, but i know you put the car in park or neutral then you can use the button to open the back glass/hatch. i know the motor for the popping mech works because i stripped a wire and used a drill battery and it popped just fine. used a test light on the switch and that worked. is there something im doing wrong? is the rear window popping mech tied in with something else, like the power locking doors? and is there a relay maybe that needs to be replaced. i dont think theres a relay but im just trying to eliminate small simple things. THANKS
Old Feb 13, 2012 | 11:09 AM
serrasalmus's Avatar
serrasalmus is on a distinguished road
mine wont operate unless it is in park or neutral i think its a safety feature
Old Feb 13, 2012 | 12:04 PM
91blazer91's Avatar
i think i also saw something that said u had to push the emergency brake in while its in park or neutral?
e602
91
Mar 8, 2015 04:53 PM
tuckerracing
Feb 9, 2011 04:45 PM
mpmWS6
Aug 25, 2010 08:47 PM
GolfClapperX
Jun 5, 2009 03:48 PM
bigghoss
Apr 15, 2007 01:39 AM
